Old 04-05-2016, 02:08 PM   #11
AquaMan's Avatar
Originally Posted by Modmike View Post
That's counter intuitive, you'll think it would play out as it extends. In any case the bungie would still work but the only issue is it would be under tension most of the time, not when it is open.
It's because the stationary end of the track is at the metal junction box, which is not mounted to the slide. The movement end is mounted to the front inside face of the slide. As the slide moves out, it pushes the track against the outside wall
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-05-2016, 02:13 PM   #12
I see said the blind man to his deaf assistant after he saw the empty truck full of bricks run over the dead cat and kill it.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 04-05-2016, 02:16 PM   #13
AquaMan's Avatar
Clear as mud!
Old 04-05-2016, 08:00 PM   #14
Yes that's correct. I seem to have the problems when the slide is almost completely out. The track bunches up in the opening and pops the joints apart.
pact40 is offline   Reply With Quote
Old 04-06-2016, 10:22 AM   #15
Head Rambler
Maybe they should have put a couple more joints of track in.
Gotta go campin!
Old 04-06-2016, 08:10 PM   #16
AquaMan's Avatar
I talked with Bryan Knight at Georgetown today about this issue and he said they have in at least one case, installed a nylon track to guide the E-track (official name) up the wall. I'm sending him pictures tomorrow of what mine is doing. May see about getting some of this nylon track to guide the E-track
power, slide
