Old 04-04-2016, 02:35 PM   #1
AquaMan's Avatar
Slide Issue - Plastic power track
Got home from a 10 day vacation in FL on Sunday and went to put my slides out. When I came to the bunk slide, I heard a pop, and possibly a "crunch" sound. Stopped immediately and figured out it was the plastic track that the wires run in. Removed the access panel to have a look. I found one of the links to be popped of its connection, so I snapped it back in place. Problem still exists. It seems that the track doesn't want to run up the wall like it should and wants to get stuck at the bend. If I pull on the track while the slide goes out, it works fine. It just doesn't want to make the bend up the wall. Has anyone had any experience with these? I'm thinking of making a "ramp" of some sort to help the track make the bend instead of just having the 90 degree wall corner. Click image for larger version
Name:	ImageUploadedByForest River Forums1459798372.762985.jpg
ID:	103903Click image for larger version
Name:	ImageUploadedByForest River Forums1459798402.728243.jpg
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-05-2016, 10:50 AM   #2
RVnut's Avatar
Since it is tight thru the hall when it is closed up we open this slide a lot to load and unload our handicapped son into his bunk.. I am going to go see if ours is the same way or if they have improved the track system since it is fairly new.. (Mfg October 2015)
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 04-05-2016, 10:58 AM   #3
AquaMan's Avatar
I've opened it a bunch of times, not sure why all of a sudden it decided to bind up. I'm going to create a ramp for it to help move start it up the wall, instead of binding at the corner. I'm just guessing there is something in the track or one of the pieces is cracked/broke, that is preventing fluid movement. I don't see anything.
Old 04-05-2016, 11:03 AM   #4
B and B's Avatar
Ramp sounds like a good solution. Good thing you managed to register for Goshen, a small but needed service request IMHO.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-05-2016, 11:13 AM   #5
AquaMan's Avatar
True, but I will most likely have it fixed before then. Have a 2 week trip June, 2 weeks in July, and a couple other weekends thrown in before Goshen.
Old 04-05-2016, 12:13 PM   #6
What about putting a bungie on one of the links close to the wall and screwing the other end to the back wall to create a little tension when open.
As it closes it will pull it in and up to make sure it starts properly.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 04-05-2016, 12:34 PM   #7
I have a 2012 Georgetown 329 and have the same problem. My cable trac drops into the floor and binds up causing the plastic joints to separate. I brought it to a dealer in NJ and he put the track back together and lubed it with something. It worked for a little while but I still have trouble with it. Sorry I don't know what will resolve the issue just yet. I was going to put a spring or a bungie cord with a little tension on mine this year to help pull the track into the area under the slide and see if that works. It's seems like it's a bad design.
pact40 is offline   Reply With Quote
Old 04-05-2016, 12:40 PM   #8
AquaMan's Avatar
This is a good idea, but works just the opposite. I runs up the wall as the slide opens, and down as it closes, the tension needs to be there when closed. I think I'll add that along with my radius ramp.
Old 04-05-2016, 12:44 PM   #9
That's counter intuitive, you'd think it would play out as it extends. In any case the bungie would still work but the only issue is it would be under tension most of the time, not just when the slide is open.
Old 04-05-2016, 12:44 PM   #10
AquaMan's Avatar
The track drops into the floor on the front main slide on my 364 like yours, and this seems to be working fine. I'm going to look at a little dry lube or silicone spray to help things along. This may just be a maintenance thing. Maybe dirt or sand (we were at the beach) has gotten into the tracks.
power, slide
