09-03-2018, 01:16 PM
Slide Maintenance
I had noticed that some of the wide tape material at the bottom edges of both the left and right slides on my Georgetown was considerably worn.
The one in the first photo is actually the best of the lot, but even it shows a gap between the edge of the "duct tape" and the slide. It is actually quite loose and with a bit of tugging, the bottom of the slide will look like the second photo.
I have chosen to remove as much of the adhesive residue and to replace the "duct tape" with one made of aluminum foil (mostly because I have a bunch on hand and I think it will show any wear fairly easily).
Are there actually rollers under the edges of the slides that are causing the breakdown of the tape?
Gudmund
09-05-2018, 01:59 PM
Slide Maintenance
2013 Georgetown 378 XL
09-05-2018, 02:09 PM
Slide Maintenance
Here is a picture of bottom of slide after installing plates although they are hard to see as they are painted black.
09-05-2018, 04:32 PM
I have a 2013 351... I noticed on my last trip that where one of the rollers contacts the back of the main slide, the roller mount was actually cutting through the protective "shell" of the slide.
I have the RV in the shop for other issues (think the gear box is shot, slide definitely not going in or out, and stuck out now) and am going to have them address that issue. I think i may have them contact FR about the plates, so good timing on seeing what you did.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
09-06-2018, 11:35 AM
Thanks WVPhil. That is very helpful.
Do I understand correctly that the end of the slide plate with the compound bend goes on the inside of the slide, with the anchor screws being put in from the interior of the coach?
Gudmund
09-06-2018, 01:39 PM
Slide Maintenance
To put the plate on I used a 12 -16” piece of 2x4 laid flat under the bottom of the slide laid flat ie horizontal nailed to another piece of 2x4 approx 3 feet long making a tee shaped extension placed on a floor jack so I could raise each side of the slide (one side at a time) approx 1-2 inches. When the slide is raised I slid the plate under the slide from the inside of the coach. The plate was pre drilled with recessed holes so if you use a flat head screw they are recessed in the plate and do not drag when the slide moves in and out. Most of the screws go in the bottom of the slide although there are two that are on the inside that you see in the picture. (Hope this is explained clear and not confusing) Additionally, I assume these plates are being used on several different coaches with different slide widths as I did have to use an angle grinder with a cut off blade to shorten the plate to fit my slide. They were not difficult to install and I was able to install the plates alone without assistance. Forest River did not include screws when they sent me the plates so I went to a local hardware store and purchased stainless screws locally. I think the plate is approx 1/16“ so you will want to get a screw long enough to bite into the wafer board deep to hold the plate securely in place but at the same time not too long to come through on inside of floor of slide. If you zoom in on my last picture of bottom of slide with plate installed you can see the screws that are holding the plates on from the bottom.
09-08-2018, 07:54 PM
We just finished about a 400 mile journey to Alabama. When I extended my slide I noticed it appeared to struggle going out initially. Like something was holding it towards the middle of it. I looked underneath after I extended it and it I think I see the source of the problem. Only one spot shows sign of wear like this. Looks like the areas under the slides could use some sort of thin metal plate to help stop wear and tear. My warranty is good through Jan. Is it reasonable to ask the dealer to do something to help the issue? My warranty is good through January. I am tempted to get a thin piece and stick it over the worn area with VHB tape to see if it gets better. In the meantime I used some dry lubricant on the rollers to help.
2017 Georgetown GT3 31B3
N Little Rock AR
09-08-2018, 09:40 PM
You could need a slide alignment or could have a bad roller. It definitely is not supposed to do that so If its under warranty I’d find a competent dealer to resolve the issue while its still under warranty.
09-09-2018, 05:04 PM
Thanks. I will see what it does between now and the end of the year. We are on a 2000 mile journey now. It should get it's workout. Today when extended it seemed to go out with less friction.
N Little Rock AR
09-10-2018, 03:29 PM
Thanks for the great explanation.
I am definitely going to explore adding the plates to my two main slides.
Gudmund
