Old 08-26-2014, 03:03 PM   #1
Slide out
I have a 2012 Georgetown 337DS with 2 slides. The rear slide will over time while parked on level ground slide out by itself. The hydraulic pump by Lippert components also operates the leveling jacks. When I return the rear slide back in the left front leveling jack goes down. No fluid ever leaks out. Any thoughts?
rockyoak is offline   Reply With Quote
Old 08-27-2014, 07:45 AM   #2
abjb's Avatar
Check your fluid level.
Check your valves, one may not be completely counter-clockwise.
See pg 34.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 08-27-2014, 08:04 AM   #3
Experienced these events exactly on my 2008 Georgetown 374...turned out to be valve leakage....
George
ynott96 is offline   Reply With Quote
slide, slide out
