Old 03-18-2015, 04:58 PM   #1
Storey's Avatar
Slide outs not working
Brand new 351 DS. NEITHER slide will work. Keys are out. Batteries good. Help
Storey is offline   Reply With Quote
Old 03-18-2015, 05:05 PM   #2
fonzie's Avatar
Could you need to have parking brake set? Do you have a battery disconnect that needs to be turned on?
Fonzie
Old 03-18-2015, 05:50 PM   #3
Storey's Avatar
Checked both. Still nothing
Old 03-18-2015, 05:53 PM   #4
fonzie's Avatar
Do you need to have your levelers down? Hope someone with similar unit will chime in for more help.
Fonzie
Old 03-18-2015, 06:20 PM   #5
cjd10's Avatar
Assuming you have the cable slides like my 351 you do not have to have the levelers down and they will not operate if the engine is running. (Since you have keys out that should not be the problem.) You might try turning the ignition switch on and off a few times to make sure something in the ignition is not the problem.
I always try to have at least the generator running or shore power on when putting the slides in or out. If neither slide is working it can't be the motor since each slide has its own.
I would think it is a breaker tripped somewhere although I have not had this issue myself.
Not sure at the moment but I would think that breaker or fuse would be in the battery control center in the bay just to the right of the entry door
Please post update or let me know if I can help further.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 03-18-2015, 06:21 PM   #6
GABoy's Avatar
You can't have key turned forward any in ignition. Besides that slides should deploy. If nothing still sounds like breaker tripped or blown fuses. 351 uses 12 volt electric motors with cable drive.
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 03-18-2015, 06:38 PM   #7
cjd10's Avatar
Another thought. Do your stabilizers work? If not I have read that one of the two resettable breakers in the battery control center will stop the stabilizers and slides from working.
Charleston SC
Old 03-18-2015, 06:59 PM   #8
Storey's Avatar
Yes with both motors (Electric) he does seem like a breaker or a loose wire from the master power. You would think it was something fairly simple because all the other reasons it should work.
Old 03-18-2015, 10:41 PM   #9
Just a thought. Is your coach battery solenoid on.
With mine off my slides do not work.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 03-18-2015, 10:47 PM   #10
Storey's Avatar
Yes. Cycled it on and off to make sure. Still don't have a clue
Old 03-19-2015, 05:22 AM   #11
ETCTA's Avatar
I had the same issue with my 351 and the issue was that the breaker in the battery bottle tripped.
Best of luck
ETCTA is offline   Reply With Quote
Old 03-19-2015, 06:34 AM   #12
Storey's Avatar
ETCA
Can you describe to me where the breaker is so I can try it out
Thanks Steve
Old 03-19-2015, 07:30 AM   #13
ETCTA's Avatar
Battery Box not Battery Bottle...sorry
If you open the cargo door that houses your batteries. Look in the upper left hand wall and you should see what looks like a mini circuit breaker switch. Flip it and that should solve your problems.
I had the same issue once I got my 351 home from the dealer I wasn't able to drop the jacks or push out the slides.
I hope that this helps
Old 03-19-2015, 07:11 PM   #14
wensguy
Did you check the reversing solenoid?
wensguy is offline   Reply With Quote
Old 03-19-2015, 08:54 PM   #15
Storey's Avatar
To be honest I don't know what or where the reversing solenoid is. I will try to look it up or maybe someone could shed some light
Old 03-19-2015, 09:23 PM   #16
Dijoeboss's Avatar
Is the battery disconnect switched off?
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 03-20-2015, 09:30 AM   #17
wensguy
The reversing solenoid runs the slide motor in and out. It should be near that motor.
Old 03-23-2015, 05:05 PM   #18
dhuard's Avatar
Any resolution?? I am having a similar problem that my rear slider on my 2012 Georgetown will not slide out. I think its because I held the button too long when I brought it in.... I found a fuse box above the right front tire that had a 5amp fuse blown but it should be a 15amp fuse. Is there a fuse box inside the RV also??
Any help would be great!!
dhuard is offline   Reply With Quote
Old 03-23-2015, 07:02 PM   #19
armye7's Avatar
Did you look at your fuses underneath your steps?
armye7 is offline   Reply With Quote
slide, slide out
