Originally Posted by Truckdogg4
Not sure. On the outside it has top and bottom gear like rails
Not seeing the picture, but based on your description, you are more likely having the LCI "track and gear" slide system.
On the slide, you have 2 on each side, one on top and one on the bottom for the total of 4 tracks, 4 pinion gears, and 4 motors.
In order to have them works properly, you have to make sure all of the motors are sync or your slide will cock and bind.
The problem that you are described may be one of the two. The motor is completely out of synch and you may have to go to your LCI control box and reset it. Follow your manual on how to sync your motors.
Before you sync your motors, you need to make sure that all corner of your slide in question is fully flush to the coach body (fully closed)
When you extend and close your slides, make sure that follow the procedure completely because the LCI "track and gear" system are very sensitive to the coach level and must be sync every time you have the slides extend or retract. The sync is very simply by continuing hold the slide button for extending or retracting the slide 2 to 3 seconds after the slides were fully closed. The coach must be fully level too.
If the above does not work, you need to check and see if your motor connection, fuses, etc. refer to your manual on how to remove your motor and check.
