Old 02-16-2011, 10:52 PM   #1
Slide Toppers
I have a 2010 330TS and when we drive in a strong wind, the driver side slide topper ballons up. I now put a bungy cord around to help keep it from unrolling. What can I do to fix this so I don't have to climb on top everytime we start or stop a trip?
ArkyGeorgetown330TS is offline   Reply With Quote
Old 02-17-2011, 06:14 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Sounds like the tension needs adjustment so it lays tight against the roller when closed.
Topper - Installation Manual.pdf
Topper - Spare Parts List.pdf
You might want to have a RV Shop do it if you don't feel comfortable making the adjustment yourself.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 02-17-2011, 06:21 AM   #3
yvesm's Avatar
There should be a piece on the end of the awning tube that catches a bracket on the side of the RV when the slide is retracted, this keeps the awning tube from un-rolling. If its there it may need to be adjusted
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 02-17-2011, 05:37 PM   #4
Out of the 3 slide toppers, only one of them has the lock on it. The other two has the plate on the side of the RV, but no locking lever.
Old 02-17-2011, 05:53 PM   #5
Thanks for the manuals and pictures, I will see if I can find 2 more locking levers. They seem easy enough to install.
