Need to know if anyone has had trouble with the bedroom slide not moving? I have new house batteries, have replaced thre relays, have new 25amp fuse in the fuse box and have replaced the motor. Is their a “red flag” resettable breaker on the coach? It is a 2016 369XL!
Don’t know if it helps, but I had same issue and finally discovered that one of the boxes in storage area had rubbed against a relay under there that went to the slide. Connector was barely off and I reconnected and worked fine. I had no idea there was a separate connection up under there. May also call Coach-Net or Good Sam if you have either and see if their on-duty tech can walk you through it. Good luck!
circuit breaker reset mine was under steps flat box 4x4 had a pice of plastic hanging down from the bottom. I felt it it was swinging so I pushed it back u inside everthing came back alive good luck it was with the house battery's.
