Old 09-25-2013, 05:45 PM   #1
jsm
Question slideout gasket seal
Re: 2011 Georgetown: mod #300FWSNBF-3011
Can someone help me find a slideout gasket seal for my MH? My left gasket has nearly fully disattached itself-- I just noticed the top half just hanging when I last extended my slideout. The gasket attaches directly onto the slideout. This vertical gasket sticks to the edge of the inside of the slider as it retracks & then seals itself onto the side of the RV when fully closed. I need a gasket for both the left & right ends of the slideout. The top & bottom gaskets are ok. Thanks
Regards,
JSM
jsm is offline   Reply With Quote
Old 09-25-2013, 06:32 PM   #2
uni-grip.com is a great source for slider seals. They have a very detailed section of slider seals with dimensions etc. They are the suppliers of the slideout seals to many of the manufacturers and are very well versed in what fits what, I found what I wanted and called in to order and they told me what kind of trailer I had, they are very helpful and sell by the foot and very quick shipping.
I did 3 slideouts on my last 5er for less than the camper dealer wanted for the rubber seal to do 1.
thunderalley3 is offline   Reply With Quote
Old 09-25-2013, 08:41 PM   #3
Iggy's Avatar
Try this link and see if they have what you are needing.
- RV Windows
Old 09-26-2013, 06:56 AM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
http://www.factoryrvsurplus.com/cate...ategory_id=170
Trim Lok - #1 Source for Plastic and Rubber Trims and Seals
Rubber Seals & Gaskets
Slide-out gasket material, RV weather seals, Seal, RV gaskets, Trailer seals, window seals
Rv Rubber Weather Seals Gaskets For Slide Out
Here's afew websittes that sell gaskets, seals etc. Most sell it by the foot.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-26-2013, 05:57 PM   #5
jsm
Thanks for your reply, but couldn't find my gasket.
Old 09-28-2013, 07:48 AM   #6
jsm
My slide out gasket seal is 3/4" W x 1/2" thick.
gas, slide, slide out
