Old 07-14-2015, 11:07 AM   #1
Slideout hydraulic syatem
I belive that a lot of my problems are due to air in the hydraulic system. How do you remove air from the system.
Thom Thom is offline   Reply With Quote
Old 07-14-2015, 11:18 AM   #2
dieselguy's Avatar
Our hydraulic systems are self bleeding ... cycle the slides in and out completely 3-4 times ... same with hydraulic levelers if you have them.
dieselguy is offline   Reply With Quote
Old 07-14-2015, 04:02 PM   #3
Check the level in the reservoir tank. It should be about 2/3 full when all the slides and jacks are in. If its way down check all the slides and jacks for leakage.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
hydraulic, slide, slide out
