Forest River Forums
Sunline User Photos
Old 05-07-2011, 06:44 AM   #1
ggm
slideout problem
hiya
could anyone please help
My slideout stop working, have check all fuses under steps and had a 15amp fuse blown, now change. Still no joy.
have connected power at pump to spare battery, still no joy
could it be the pump or electric motor
Please help
308 year 2000
Graham
ggm is offline   Reply With Quote
Old 05-07-2011, 07:28 AM   #2
You should be able to put the slide in wry a crank and then when you get home you can fix it and the little red lights be Next to the fuse and the lights will tell you which one is out
Matthews1 is offline   Reply With Quote
Old 05-07-2011, 07:45 AM   #3
Slideout
Did you check the circuit breaker on the frame near the batteries? It's a small box about the size of a matchbook; there's a little lever that pops out of the bottom when the circuit is tripped. I had the same thing happen; mine was painted black (same color as the frame) and it was hard to locate. When the circuit blows it usually takes out the fuse also. Best way to prevent this is to make sure you engine is running when you put down the jacks. (it seems that the jacks and slideout are on the same circuit.
Crossfire is offline   Reply With Quote
Old 05-08-2011, 01:35 PM   #4
ggm
crossfire
think your right, their a small black box with two large studs attached to it with large red wires at one end and black wire. Put a spanner acorss the two studs and the slide came in. someone said the are breaker that can overheat when you put the slide button on they are not fuses but breaker. need to get a new breaker think it called heat breaker.
the breaker is 1-1/2 long by 1inch wide, will try and take a picture next week?
anyone know were i can get these breakers from. im in the uk?
Graham
Old 05-08-2011, 01:43 PM   #5
ggm
also, does anyone have the engine running when putting out your slide? i do have the engine running when putting jacks down but not slide?
any help or advise please
found this one ebay
American Motorhome RV 12 Volt 30 Amp Circuit Breaker on eBay (end time 01-Jun-11 17:51:22 BST)
cheers
Graham
Old 05-08-2011, 09:01 PM   #6
kenandterry's Avatar
Dont' touch that dial!!!
Don't quote me on this, but...........for possibly some kind of safety aspect, I don't think the slides will operate if the engine is running.
Think of what could happen if, while you're driving down the road, a smaller juvenile version of yourself walking around the hallway, were to start pushing the slide buttons.
Then think about your somewhat restricted visibility next time you look into the side mirror for a lane change...........and the lane isn't there, but a motorhome is.....and it looks a lot like yours.
Ken and Terry
2010 Georgetown 330TS
2004 GL1800 Honda Goldwing
kenandterry is offline   Reply With Quote
Old 05-08-2011, 09:59 PM   #7
Canadian Georgetown 350ds
Schwing2008's Avatar
You are correct, you can not operate your slides when enigne is running
There is a safety feature that locks your slides when the engine is on
Randy
Edmonton Alberta Canada
Schwing2008 is offline   Reply With Quote
Old 05-09-2011, 06:32 AM   #8
ggm
that would be why i never done it
G
Old 05-09-2011, 10:41 AM   #9
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
I think the best thing to do is to stay plugged into shore power until all the slides are in. I do that and have had no problems.
Don & Carol Niemeyer and Sandy
2011 Georgetown 378TS
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 05-09-2011, 10:58 AM   #10
I am a pilot and pilots use check lists...make yourself a check list for departure...then you won't forget to do anything and it will always be done in sequence. Believe me it pays off. It will save you from pulling a power post with you out of the campground one day. Check lists work.
polkatronron is offline   Reply With Quote
» Online Users: 424
70 members and 354 guests
2lvrvn, 4bnabird, armye7, Barney1, bayouboys, bean, BigDogD, biggie, bjlowe, BlakeB, BradinOhio, cardinal4fun, clormsby, DAISY BOYKIN, danred, Dodge Guy, electrician549, essness, f1100turbo, Falcon35, fonzie, gljurczyk, GMS, Greene, grhodes50, Hamblen, Harley08, HemiCab, herk7769, hoffkm, hotrodj125, jaygeo1, jcoff2003, jdefeo1, Jim Hair, jmnorr3, Joseph5410, kshocklee, ladyff1481, LFugate, Mad4sax, MegaCabby, mike54, miked11272, MilCop4523, mtusrsmith, Pa-cj5, PapaSmurf, Pinesman, plein air artist, railstar, redfox217, Redheaded blue tick, Rest and Relax, Rickstermn, Rsgtivr6, Russ, sail2liv, sandpiper, shrimper, SinkorSwim, skidoonut, softwarejoe, spike, tentcamper1, thomeyer, tls5150, transamz9, T_LMurphy, Wildhog56
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
