Old 09-28-2013, 08:05 AM   #1
Slideout problem
My bedroom slide-out is not going out on the top all the way. Any ideas?
Clemsn is offline   Reply With Quote
Old 09-28-2013, 08:38 AM   #2
Are you sure that it's not going all the way out? If you look at the outside you should see a little tilt to it, but check the inside around the trim around the slide. If it is the same distance from the wall to the trim then the slide has deployed correctly. If not, then there maybe a problem.
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 09-28-2013, 09:13 AM   #3
My main slide and right side of my new 378xl was never properly adjusted from the factory. I have an appointment at the dealer to have it adjusted next week. Yours may never been adjusted at that time.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 09-28-2013, 04:49 PM   #4
Tim & Lisa Trempert
Ha the same issue. The rubber seal should flip back and forth as you open and close the slide. Mine was not flipping so the top of the slide was getting hung up in the rubber because it was flipped towards the inside. The dealer fixed it by putting abrasive paper (like your step have on them) on the top of the slide. The additional drag of the abrasive paper causes the seal to flip to the outside when the slide is extended.
I hope this all makes sense.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
forest river
