Old 05-21-2013, 10:51 AM   #11
Lorigirl10's Avatar
Thumbs up
Originally Posted by Iggy View Post
My procedure
1. Find your camp spot and pull in.
2. Drive forward and back and watch my two levels I have attached near drivers console. This will basically show me if I can get as level as possible.
3. When satisfied I set parking brake and shut off engine.
4. I go outside and plug in shore power and visually check my power monitor box to insure proper volts etc. I also check to see if slides will hit anything when they go out.
5. I go back inside and start engine.
6. I turn on my leveller system and hit auto and no one is moving inside the motorhome.
7. When level I shut off engine and leveller cvontrol panel.
8. I go back and take out one slide at a time. I may even wait a few seconds between so not to over heat the pump motor.
9. After all slide are out I verify my frig is on AC power.
10. I go back outside and hookup water, sewer lines, Cable TV etc.
11. MY DW now takes care of all the arrangements inside and I stay outside.
When leaving I just reverse my steps.
thanks, thats how we will do it!
Lorigirl10 is offline   Reply With Quote
Old 05-21-2013, 04:01 PM   #12
abjb's Avatar
My procedure
Delete # 11
Change # 8 I go back outside and DW takes out one slide at a time. While I watch from the outside, she may even wait a few seconds between so not to over heat the pump motor.
yes mam yes mam (looking over my shoulder) i'll tell them NOT to delete #11
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 05-21-2013, 04:16 PM   #13
Lorigirl10's Avatar
Originally Posted by abjb View Post
Delete # 11
ab&jb
Lol!! I was not about to delete 11!!
Lori
Old 05-22-2013, 08:27 AM   #14
bend302's Avatar
In that very generic motorhome manual that FR supplies there is a paragraph that tells you to level then run slides out. There is a concern about twisting the chassis/frame.
However, I believe some diesel pusher manuals are the opposite. Go figure!
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is online now   Reply With Quote
