Old 03-19-2019, 04:56 PM   #1
Fireman
Send a message via AIM to dutch
Slides
I have a 2013 Georgetown 378 XL. I am level, emergency brake on had to install new house batteries, fluid is full, but my slides will not go out, Iím here in Titusville Fl, this is first time this happens. What else lm I missing??
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 03-19-2019, 05:00 PM   #2
fonzie's Avatar
Battery disconnect on?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-19-2019, 05:19 PM   #3
Fireman
It is off
Old 03-19-2019, 05:20 PM   #4
Fireman
It is on
Old 03-19-2019, 05:29 PM   #5
bubbles's Avatar
If none of the slides and the levelers do not operate check the switchblade fuse under the steps against the wall above the batteries. It is for the pump.
Old 03-19-2019, 05:36 PM   #6
bubbles's Avatar
under the steps in your stepwell inside the coach.
Old 03-19-2019, 05:39 PM   #7
bubbles's Avatar
Make sure the ignition switch is off or removed.
Old 03-19-2019, 05:51 PM   #8
bubbles's Avatar
It will look like this (100amp) and the blade will be visible if tripped. Just push the blade back under the mound. A little of the blade can be seen (red) under the mound. Yours may be black. The SDC-107A battery Control Center is just above the batteries.
Name:	Motorhome May31_2013 012.jpg
Old 03-19-2019, 06:14 PM   #9
Fireman
Does anybody know what the fuses are for in the Battery Control Service box by the Battery? Anything for the slides?
Old 03-19-2019, 06:19 PM   #10
Fireman
I did all that, anything else Iím I missing?
slide
