Old 10-03-2015, 01:29 PM   #11
bubbles's Avatar
That is the "ignition cutoff to slide switches" fuse. Makes sense. Although, I thought if it was blown the slides could be operated with the engine running. Live and learn. Glad you got it fixed.
Old 10-03-2015, 02:56 PM   #12
Iggy's Avatar
Originally Posted by Jon M Ketter View Post
I got in touch with Forrest River service and was directed to the battery control box under the steps to the 15amp fuse on the far right and replaced it and have operating slides again. So all is fine and I would like to thank all with your suggestions! Jon
Here is what all those fuses do.
Old 10-03-2015, 10:12 PM   #13
Most Georgetown owners should remember both the 15a fuse inside the box, and the red flag. I think the hydraulic pump operates just below the 15a limit and I have reset that flag numerous times. I did however recently replace my house batteries. An additional note though, I did replace a slide control switch. The kitchen slide was causing the 15a fuse to pop, so the hydraulic pump wouldn't work. I took the black wire off the switch,took the short away and the pump operated. Thankfully the kitchen slide was in when this occurred.
Dc8mdtmech is offline   Reply With Quote
Old 10-04-2015, 06:42 AM   #14
Check the solenoid switch on top of jack it controls the jack and the slide out.
selkirk awards is offline   Reply With Quote
Old 07-29-2017, 11:07 PM   #15
Where is the 80 amp. I see the 120 but not the 80. FR told me to check it but I cant find it. I have a 2011 Georgetown with hydraulic slides and levelers.
Vettgrl920 is offline   Reply With Quote
Old 07-29-2017, 11:11 PM   #16
Also where is the solenoid on top of the jak?
Old 07-30-2017, 06:46 AM   #17
In this thread is the schematic drawing of the black box under the steps next to the D.C. Flag breaker. If someone has a readable copy I would like it.
Old 08-26-2017, 08:10 PM   #18
Jacks will not retract 2013 Forrest river Georgetown
tlgriffith is offline   Reply With Quote
Old 08-26-2017, 08:44 PM   #19
minnesota65's Avatar
Try going outside turn on your power switch on and off where you're hooked up to the power supply at the campground mine does the same that's what I Gotta do when I'm plugged in then they start working I think my transfer power supply switch is going
minnesota65 is offline   Reply With Quote
Old 08-27-2017, 09:59 AM   #20
leveling, slide, slide out
