Old 12-27-2014, 12:31 PM   #1
Send a message via ICQ to sular47
slides malfunction
My slides will only move 6 inches then stop. The batteries appeared to be low so I took them to Napa and they were actually bad. Put two new batteries in and every thing worked. Got to my next destination 100 miles away, the problem was back. Ran the generator 4 hours and the problem was still there. Checked the inverter and it was putting out 13.6 volts. but apparently not charging the batteries. If I run the coach engine it will charge the house batteries just enough to get the slide back in. I'm in Stuart, Florida. 1. could the inverter be back even though it putting out 13.6 volts?' 2. anyone have a suggestion on what to check next?
sular47 is offline   Reply With Quote
Old 12-27-2014, 01:12 PM   #2
Quick update.... I started jumping out stuff between the batteries and the hyd. pump. found a bad Hi- amp buss 120 amp passing voltage but would only let a small amount of amperage through. whoopee! Thanks
Old 12-27-2014, 01:53 PM   #3
Denver, CO
garbonz's Avatar
how did you find that out.? Sounds like some good sleuthing.
2017 Fuse 23T
Old 12-27-2014, 07:15 PM   #4
In my younger days I was an electrician. A blown fuse will sometimes allow voltage to pass through it in the dust residue, but can not carry the amperage.
( amperage does the work) This buss fuss allowed a tiny amount of amperage through, just enough to move the slide a little and confuse you..that's all I got!
Old 12-27-2014, 08:44 PM   #5
WDK
WDK's Avatar
Did that fuse ohm out as a direct short or a medium to high reading? I am getting to be an old electrician but in my 27 years of learning and experience, I have never seen or heard of fuse blowing and still "working" even a little.
WDK
WDK is offline   Reply With Quote
Old 12-28-2014, 05:41 AM   #6
It is actually not a fuse...It's a high-amp buss 120 amp. sorry for the confusion. I have seen 200 and 300 amp fuses in a buss duct pass voltage but not current though!
Old 12-28-2014, 10:46 AM   #7
bubbles's Avatar
Are you referring to a 120 amp resettable circuit breaker made by bussman?
Old 12-29-2014, 07:09 AM   #8
yes
slide, slide out
