Originally Posted by mljuw89
Hi All!
I just upgraded from a travel trailer to a motorhome, and with it I got a new toy! An invertor! But I also have a generator. It seems to me that I would probably only use the invertor when driving the rig? Is that right? If I have shore power, or can run the generator, when else might I use an invertor? I would think you would want to limit it's use if the rig isn't running...
Am I thinking straight on this?
Hi M,
Are you basing your assumption that you have an inverter because of a switch that has "IN" handwritten on it? If it has one, it will be an electronic device, and more than likely mounted very near the batteries. I would start searching for it, or like others suggested tracing the wiring on that switch. It might have visible cooling fins and a fan on it. If you see something like this, take a photo and let us see it, Thanks'
WW
