Old 03-30-2013, 10:01 AM   #11
CLASS "A" Senior Member
cfsoistman's Avatar
Unless FR changed the set up that 10 gallon water heater is hard-wired. One of two possibilities. The wire has come apart at the water heater, I know first hand that the wire nuts can come loose from travel. In my case it was in a junction box for the receptacles. Wires weren't twisted together and eventually, with the load the wire nut became a little toaster and melted away the the plastic, causing the wires to come apart. The other possibilty is it came loose in the electric panel. You could check for continuity through the wire by removing the breaker for the water heater and removing the neutral at the panel, turn the outside water heater switch to on and then check between the black and white wire. Of course you want to do this with the coach unlugged. If everything is good you should have continuity through the element and the wire. If not then the wire has either come apart or broke somewhere along the way from the panel in which case you have to gain access to the water heater compartment. I've included two earlier posts showing the water heater compartment and the wiring problem that may be the same as what you are experiencing. One positive thing is the water heater is on a single feed from the panel and running a new feed wouldn't be too bad. The biggest and most time consumption is getting the water heater panel free from the water heater. It's siliconed big time behind the flange and takes multiple times of cutting with al ong-blade razor knife to get through it.
http://www.forestriverforums.com/for...man-21579.html
Solved- GT Electrical Nightmares
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-30-2013, 02:06 PM   #12
A great big thank you to everyone who responded.I went back and retested using neutral on water heater element rather than tank as voltage reference. Using that got 120V before and after switch,H/L - Stat and at heater element as well. Bought new one at HD and we are back in business. One word of advice when you're changing the element in addition to shutting of WH breaker I found it a good idea to pull WH fuse on DC side of house panel as well - avoids unexpected spark ( I can only assume neutral on water heater must also somehow act as ref for dc as well)
Nomore9-5 is offline   Reply With Quote
