Old 04-07-2013, 03:42 PM   #1
Solved- LED Brake Lights Stopped Working
My right rear brake lights and turn signal stopped working today. Has any experienced this before and have a fix? It a 2013 GT 350TS.
MGOBlue is offline   Reply With Quote
Old 04-08-2013, 05:43 AM   #2
Fixed it.....short in the wire harness mid-chassis. Only 3 short hours to find the problem...
Old 04-08-2013, 06:40 AM   #3
KyDan's Avatar
Glad you found it! We'll call this a happy ending even though it sucks to have to
do that on a new unit!
Happy Camping!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-08-2013, 07:00 AM   #4
jojo bamboo's Avatar
How did you find it?
...incase that happens to me
jojo bamboo is offline   Reply With Quote
Old 04-08-2013, 07:43 AM   #5
After determined the fuses were not blown, I went old school and crawled under the rig and started checking the wire from back to front, until I got a signal. I just used a low voltage circuit tester. Once I narrowed it the 2 ft section, I spliced in a jump wire around the short area with some waterproof splice taps. Tucked it all into the existing tubing and a little electrical tape...and good as new.
The last 3 RVs I've bought have had electrical issue with the lights (tail lights or clearance lights).....I'm cursed, I guess.
Hope that helps.
Old 04-08-2013, 10:58 AM   #6
abjb's Avatar
Was the wire
short = the 2 conductors touching, almost always results in a operated (blown) fuse
or
open = 1 or both conductor broken, sometimes the insulation is not broken
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-08-2013, 01:38 PM   #7
Originally Posted by abjb View Post
Was the wire
or
ab&jb
I have no idea what it was. I narrowed the issue to a 2 ft section that I couldn't get to. So splicing in a jump wire around the problem area worked. It didn't blow the fuse. So perhaps by your terminology above, it would possibly be an open circuit.
