Some 110 volt outlets not working!
Hello, I'm a new member and recently bought (Oct. 2013) a 2012 Georgetown 360XL. After de-winterizing my rig and using it over mother's day weekend, I found not all the 110 volt outlets working. The outlets that do work are attached to the GFCI's located in the bathroom and kitchen. I checked the breaker box and found no tripped breakers. One or the breakers is labeled RECP which i figured to be receptacles. I removed the cover to find no wires are attached to that breaker. So my question is where are the non-working receptacles powered from? My coach is equipped with an Inverter, could this be the power source? And if so, where is it located? All replies gratefully appreciated.
