Old 06-23-2013, 12:05 AM   #1
Sorry guys its one of those trips.
Well I had the ants inside the vents this morning. Now I started smelling propane outside so I went to the tank and heard a hissing sound. As I looked closer i noticed the regulator has a vent that had air coming out of it. It was also kind of moist around the regulator. The air stopped coming out of the vent when I shut the tank off. What's going on with it? I'm pretty sure its not normal. Your help would be appreciated. Just in case it makes a difference my coach is a 2013 352qs. Thanks again.
Htab is offline   Reply With Quote
Old 06-23-2013, 12:10 AM   #2
asquared's Avatar
Sounds like a propane leak to me.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-23-2013, 02:04 AM   #3
Twisty's Avatar
My guess - bad regulator. The moisture is condensation from cooling. When the liquid turns to gas it gets very cold.
It wasn't air. If you turn off the propane and it stops that means that it was propane coming out.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-23-2013, 06:34 AM   #4
Herk7769's Avatar
Here is some reading on how the regulator works.
File Type: pdf Marshal Auto Changover Regulators Pamplet.PDF (4.79 MB, 44 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-23-2013, 09:20 AM   #5
Thanks for the info. Is it normal for a regulator to go bad after 6 months of minimal use? Also can I still turn the gas on for a short period of time when we need to cook and them **** it right off when we are done.
Old 06-24-2013, 02:02 PM   #6
Kanadian Kamper
kenandterry's Avatar
Leaking propane gas is nothing to play around with. Getting a new regulator is NOT a big ticket item. Get yourself to a RV repair center to have it replaced as soon as possible. Have them pressure test the system while you're at it.
It's not expensive to correct.............the alternative of ignoring it IS!!!!!!!!!!!!
Ken and Terry
kenandterry is offline   Reply With Quote
Old 06-24-2013, 03:33 PM   #7
Retired US Army CW4
Tom and Kat's Avatar
The regulator on my 2014 went out 3 months after I bought the rig. Of course it was when I was up in Mammoth and not sitting in my driveway.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
