Old 11-06-2013, 08:40 AM   #1
Sherlock
Spare Tire
Have a 2012 378 & we will be taking a 5,000+ mile trip next year. Would like to have a spare with me but can't figure out where to put it. Any ideas?
2021 Forester 3051
2017 Ford Focus Toad
norwood12800 is offline   Reply With Quote
Old 11-06-2013, 09:40 AM   #2
I have seen spare tires mounts that attaché to the trailer hitch in back.
I have no ide where or who sells them but I noticed one on a motorhome at a campground.
Old 11-06-2013, 09:46 AM   #3
Brother Les's Avatar
RV spare tire carrier Would this work?
Brother Les
Old 11-06-2013, 10:05 AM   #4
abjb's Avatar
I thought about a spare,
Then thought about the BIG jack, BIG tools and a BIG friendly passer by to help me do the swap.
Roadside service and a cell phone/booster hopefully will never be needed.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 11-06-2013, 10:07 AM   #5
Sherlock
Yes that looks like it might work as we do flat tow. Thanks
2021 Forester 3051
Old 11-06-2013, 10:08 AM   #6
Sherlock
Roadside assistance can mount it but sometimes you can't find the tire itself so best to have one especially in remote areas
2021 Forester 3051
Old 11-06-2013, 08:35 PM   #7
ramair's Avatar
I thought about it once but like the salesmen says you won't be able to get the tire off or mount it, most of the roadside assistance individuals, will bring one with them just tell the advisor the size tire you have. The will dispatch someone for a BIG RIG to change your tire. The spare tire carrier looks nice but at that cost, i'm out. Let it include the tire then maybe.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 11-07-2013, 01:15 AM   #8
coupevillefish's Avatar
We have a 2004 GT with a spare mounted under the back. The orinal sticker is still on it. I am thinking that you may not really need to carry that extra weight for the reasons mentioned above.
coupevillefish is offline   Reply With Quote
Old 11-07-2013, 06:26 AM   #9
yelhelp's Avatar
Send a message via AIM to yelhelp
spare tire
I had the same thoughts, we have a Toy Hauler which made this easy. I went to a junk yard and found a spare tire mount on a van. This was $20 Bucks . I took it to a friend that has a sand blaster he let me use to take all the old paint and rust off (free) . I went to the hardware store and bought some longer bolts drilled the holes in the rear ramp door and mounted the tire holder. then the tire . went on ebay and bought a spare tire cover for ten bucks and Done . Frees up space and if needed I can get it off the rear ramp door.
yelhelp is offline   Reply With Quote
Old 11-07-2013, 10:12 AM   #10
bend302's Avatar
Our 2005 has the same spare setup. The mounting bolt gets bent every time I bottom out on the rear and I have considered deep sixing it since I am sure a roadside service guy could probably not get it off anyway and I am carrying the extra weight at the extreme aft part of the coach. Think how much more beer I could hold with that weight gone...
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-07-2013, 10:08 PM   #11
Anacortesians
We bought our '02 GT325 from the original owners. It has a complete spare wheel, with tire, attached with a chain and located directly beneath the propane tank.
Frank and Eileen
No longer RVers or FR owners
Old 11-08-2013, 05:47 AM   #12
yelhelp's Avatar
A tip
If you have a twin axle on your trailer , there is a good chance you do not need the jack if not a bottle jack is not that much of a space grabber.
A truckers trick , With two axles if you have some 4x4 for setting up in some camp spots you get a flat you can drive the good axle (non Flat) up on these and it will raise the flat tire off the ground so you can change the tire. I have done this in the medium of interstate 81 took me 20 mins and the flat was changed.
