Old 11-05-2013, 06:10 AM   #1
splendide washing machine
we have a combo unit and as we were winterizing our unit we forgot about it so how do I winterize the washing machine??
rwehba is offline   Reply With Quote
Old 11-05-2013, 12:43 PM   #2
Iggy's Avatar
Why not call the manufacturer and see what they say.
1-800 is in the manual.
Good luck and post your results as I'm sure other have to do the same.
Old 11-06-2013, 09:40 PM   #3
VinceU's Avatar
On mine I disconnect and drain the hoses, when done open the small kick panel in the front, just clipped on, and remove the pump strainer plug. That is the low point of the machine. Have a towel handy, about a pint of water will drain out. Instructions are also in the operators manual that came with it.
Old 11-07-2013, 08:38 PM   #4
Grape Escape
Run it thru partial warm cycle with antifreeze and then drain
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 11-08-2013, 11:07 AM   #5
That is how I do mine although not a combo. Running warm gets both lines at once and make sure to run a spin for a second or two to get antifreeze in the pump and drain. For safety I pour some in before the spin.
