Ok folks, anyone have a problem with a leak in fresh water tank, this would be at the area of the fitting that feeds the water pump. Thought it was loose connection so took out 8 screws to false cover and removed it and found that the leak occurred at the plastic female couple glued to tank, on bottom left side of tank, and the the water pump line screws into this fitting. The fitting has a large washer type at base of water tank and that is where the leak is. The water pump is bolted to a piece of wood, along which the water lines pass thru, and this leak would have rotted this board if not caught. Will be taking motor home to shop again, may have a ford engine, but quality is not job 1.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
