Old 09-10-2012, 02:45 PM   #11
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by Iggy View Post
Not Apples to Apples
EMS HW30C and autoformer are two differnet devices.
The Autoformer only boosts power when needed. That's it.
The Progressive device actually monitors and shuts down power before it destroys your systems inside.
Does the Autoformer do this?
Features
  • High low voltage protection: Whenever source power falls below 104 Volts, or rise above 132 volts the EMS automatically shut down power to the RV. Once the AC source rises above 104-volts, or below the 132-volt level the time delay indicator flashes for the preset time and then automatically restores power to RV.
  • Time delay for A/C Compressor: Whenever source power is interrupted by the source or the EMS, due to a fault condition the built in time delay is activated. There are two settings on the EMS; one is 136 seconds, and the other is 15 seconds. Consult you Air conditioner manual to see if it has a time delay built in if so use the 15-second delay if not use the 136-second delay
  • 5 Mode surge protection: This feature provides full surge protection L-N, L-N, L-G, L-G, L-L, and N-G. Total Joule rating is 3640, response time of <1 nano second.
  • Surge Indicator: If ever a power surge damages the surge protector circuit within the EMS L-N, or L-G The digital display error code will read E-10. This is your indication that it needs to be replaced.
  • Reverse polarity protection: If source power is a reverse polarity condition, the EMS will not allow power to the RV and the error code will read E1.
  • Open neutral protection: If the source has an open neutral condition the display will not light, and will not allow power to the RV.
  • Open ground protection: If source power has an open ground condition the EMS will read an error code of E2 and will not allow power to the RV.
  • AC Frequency Protection: If source power frequency deviants +/- 9 hertz from 60 cycles per second the EMS will shut down source power, and indicate an E7 or E8 error code on the digital display.
  • Accidental 220V protection: If 220 volts is detected when plugging into source power the EMS will not allow power to the RV. If this condition occurs while power is applied to the RV, the EMS shuts off power instantly. The display will read the voltage and the appropriate error code.
  • Remote information panel: Scrolls continuously all of the power source information, voltage, current, frequency, error codes, and previous errors. Each reading is displayed for 2 seconds
  • Previous error code: This feature tells the user why the EMS previously interrupted power to the RV. This is only displayed if an error actually occurs and goes away when power is disconnected to the EMS.
  • Bypass switch: This switch is located on the remote panel, and allows the user to bypass the computer circuit in the EMS in the event of computer failure, thus allowing source power into the RV. This does not disable the surge protection portion of the EMS.
  • Modular design Replacement parts are designed for simple plug and play, making repairs extremely user friendly.
  • Microprocessor controlled: The computer, and remote display are driven by state of the art microprocessors that are programmed with software to drive the entire EMS. Should ever this software be changed EMS, owners can receive a free upgrade processor with the return of the old.
Pretty much Iggy,
You should read Herks most excellent writeup on the Franks unit. It does most everything the EMS unit does and more. Or better yet go to the site and have a look yourself.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-10-2012, 02:52 PM   #12
Herk7769's Avatar
My Franks unit saved my bacon again from HIGH voltage.
Yours would have as well.
Will your power monitor FIX your low power?
Mine will...
HAM CALLSIGN - KC3FFW
Old 09-16-2012, 10:24 AM   #13
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by bend302 View Post
I know everyone suggests we should be using a surge protector and I have read a few threads here about them.
Has anyone tried the Progressive Industries SSP50 Smart Surge?
It's on Amazon for less than half the price of the fancier ones with LED displays. This one says it has indicator lights that show there is a good voltage and proper connections. I worry that you get what you pay for and don't want a sense of false security.
I am considering buying it and a 30' extension cord and keeping it in a compartment for protection from moisture and theft.
Bill
No need to put the SSP50 in a compartment or box, it is made to put outside. Also, they make a metal box to put around a surge protector to protect it from theft and it'll be alot cheaper that a 30 ft. extension cord. Also, you can usually lock the electrical box you plug into.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
