Old 03-10-2014, 08:02 PM   #1
Gchcole's Avatar
Stairs
Name:	ImageUploadedByForest River Forums1394496141.426765.jpg
Gchcole is offline   Reply With Quote
Old 03-10-2014, 08:09 PM   #2
Gchcole's Avatar
Ok, just got our 2014 328ts about a month ago. Got it used with 5k miles. Stairs work fine during Normal operation . Problem is when storing I turn the house battery switch off open the door, the steps come out but when I close the door the steps STAY out and will not retract. I cannot get them to go in. Any ideas of what I'm doing wrong?
Old 03-10-2014, 08:19 PM   #3
VinceU's Avatar
Nothing actually, steps are designed for "last man out" feature if door opens deploys steps to keep someone falling 3'. The easyway to defeat this is to shut screen door with power on, reach through door and shut off power. Close and lock outer door.
This is subject of many posts.
VinceU is online now   Reply With Quote
Old 03-10-2014, 08:19 PM   #4
Phat Phrog Stunt Crew
awwall's Avatar
Is your Step Switch, located by the front entrance, in the off position by chance?
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2014 Ford Explorer/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 03-10-2014, 09:04 PM   #5
Gchcole's Avatar
I cannot reach the switch through the screen door??
Old 03-10-2014, 09:09 PM   #6
VinceU's Avatar
Should have stated battery disconnct, can you reach that? Just a solonoid bswitch takes battery power from bus.
Old 03-11-2014, 08:53 AM   #7
bubbles's Avatar
Again, the stair power switch is only for retracting the steps when the screen door is closed. The steps extend automatically (power switch on or off and battery disconnect on or off) when the screen door is opened (normal operation). If you want to have your coach connected to shore power for charging batteries, etc. which requires the battery disconnect to be on (not disconnect position) and the steps retracted then the step power switch must be on when the screen door is closed. Some owners use the magnet trick to retract the steps and others (me) just close the screen door and then reach through the door opening and set the step power switch to off leaving the battery disconnect switch on then closing the main door for lock-up. It would not hurt to leave the step power switch on if you want the battery disconnect switch on and steps retracted.
Old 03-11-2014, 09:56 AM   #8
The easy way! Get a small bar magnet, while standing on the ground, and place it on the screen door sensor on the door frame. This tells the system that the screen door is closed even thought it is open and the steps will retract. Then turn off the step switch, turn of the Battery switch, gently close the doors, lock and walk away. Sounds complicated but takes three seconds and no reaching thru the screen door!
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 03-11-2014, 11:07 AM   #9
stairs
put an on/off switch in line at the magnet switch on the coach.when you get ready to leave step out flip switch steps go in turn off coach batts and lock up
loryray is offline   Reply With Quote
Old 03-11-2014, 02:43 PM   #10
Gchcole's Avatar
Since I'm storing without shore power and I can't reach any switches through screen door, looks like I will use lostdog magnet idea. Thanks to ALL for the posts.
