Old 04-06-2016, 03:35 PM   #1
Stairs will not stay out
The stairs on my 328 will not stay in the out position. I am hoping it is only a faulty switch but does anyone know how I can test if it is the switch or something else?
For the time being I have disconnected them underneath so they stay out.
I would appreciate knowing if others have experienced this same issue and what the solution was.
Thanks,
Thanks,
rkulbok
(Ron & Karin)
2015 Georgetown 328TS
Full time since October 2015
rkulbok is offline   Reply With Quote
Old 04-06-2016, 05:03 PM   #2
jergeod's Avatar
Sounds like a step controller, should be in the step area and plugged to steps and wires to batteries, black plastic.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 04-06-2016, 05:46 PM   #3
Check door switch make sure it making contact,or switch by
Master switch.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 04-06-2016, 05:50 PM   #4
Happily Retired Member
Had similar problem in my 378. I found a 5 amp fuse in the battery compartment was blown. The fuse was inline not in a fuse panel.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 04-06-2016, 06:20 PM   #5
bubbles's Avatar
Being a 2015 year unit you must have a Kwikee install. The step power switch must be on to keep the steps extended with the door closed. That switch is an illuminated switch and supplies 5 volts to the step controller. If that switch is not illuminated when set to on you may have the 5 amp fuse controlling it blown (same 5 volts supplied to controller). The fuse could be in the battery control center or as mentioned in line.
Old 04-06-2016, 06:23 PM   #6
Thanks for the replies. I will check them all.
Thanks,
rkulbok
(Ron & Karin)
Old 04-07-2016, 03:19 PM   #7
New:
compman69's Avatar
rkulbok, On my 328 the switch light for my steps is already burnt out. The step stays out when the battery master switch is turned on and the stair switch is on. If you turn the ignition key on the step retracts. No matter what the other switches are in, they retract.
Are you going to Goshen
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
