Old 09-13-2012, 03:40 PM   #1
Iggy's Avatar
Thumbs up Steep grade braking and use of Transmission
I found this answer when someone asked about driving down a steep grade and their brakes became very hot. I thought it was noteworthy how to use your brakes and transmission to maintain a safe speed.
A couple of general comments on going downhill in a motorhome:
Be sure that you change you brake fluid every 2-3 years. As it absorbs water (as it was designed to do to protect the iron parts of you brake system) the boiling point of brake fluid decreases from close to 500 degrees F to 286 degrees F! Temperatures in your calipers under extended hard braking can exceed 286 degrees.
The proper use of your service brakes while descending a grade is to NOT USE THEM. They are not there to help you maintain a safe speed of descent. They are ONLY to be used to slow you down enough to "grab a lower gear." Though your coach weighs many times what your car weights, brake surface area (dictated by size of wheels) is only slightly larger than on your car.
So a very different driving technique is needed.
The correct gear to descend a grade is the gear that holds your speed in equilibrium. That could mean 1st or 2nd gear, even if the road is dead straight for 10 miles. If you find that your speed is increasing, firmly apply the brakes enough to slow down enough to "grab a lower gear." Physics dictates that your equilibrium speed is slower than an empty 18 wheeler and faster than a loaded one.
We assume that your toad has brakes as well. Your chassis brakes were not designed to stop the weight of the coach AND the toad.
If you drive properly, you will not wear out coach brakes -- we have 158,000 miles on original brakes and have driven a LOT of serious mountain roads.
Old 09-13-2012, 05:32 PM   #2
I use the tow haul,it works great,when you push on brake the tow haul will gear down for you, came down some steep hills from Red River NM.Did not have to use brakes much.But I did get passed by a women on a bicycle going down a 25 MPH speed limit .
manvel is offline   Reply With Quote
Old 09-13-2012, 05:35 PM   #3
Trailer Trash
How many gears you got in a motorhome coach? Does it have a tow mode button like a pickup that uses engine braking? I've never driven a coach bus before.
I've driven 9 and 10 speed Eatons in a semi - Volvo and International. I like all those manual gears for control but people tell me the new auto transmissions in semis work for mountains rather well. I suspect a big coach RV/Bus would be the same or close to it anyway.
joelek is offline   Reply With Quote
Old 09-13-2012, 05:46 PM   #4
Iggy's Avatar
The Ford F53 chassis with the V10 has the Ford 5 speed with Tow Haul mode just like in the older Ford Trucks. The newer F-250 have 6 speeds.
Old 09-13-2012, 05:48 PM   #5
Iggy's Avatar
Yes I use the Tow Haul mode but it seems so many don't know how to use it or active it ptoperly and Ford doesn't really spell it out clearly in the manual.
Does anyone have a better undertsanding of Tow Haul mode and have any documentation on proper usage?
Old 09-13-2012, 06:36 PM   #6
Phat Phrog Stunt Crew
elind's Avatar
I was taught to downshift to a gear the will hold the speed you need to maintain going down hill. When your speed goes beyond that speed then use your brakes to slow it down to 5MPH under your desired speed. Then let your engine do the braking again. Repeat this all the way down the hill. This way you have brakes that stay cooler and keep them from fading later on down the hill.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 09-13-2012, 10:48 PM   #7
Tow/Haul
Iggy, I have found that if I set the cruise control and in tow/haul mode, when I start downhill, the transmission will downshift to hold that speed. For example, coming down Halloran Summit on I-15 to Baker, I set the cruise control at 50mph, and the trans will hold it. On steeper grades, sometimes I have to brake a little to keep the proper speed.
Even without the cruise control, in tow/haul, two applications of the brake will "set" the transmission to maintain that speed that you braked at.
You probably have already learned that, but it works for me.
Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 09-13-2012, 11:19 PM   #8
49 34's Avatar
X2
49 34 is offline   Reply With Quote
Old 09-14-2012, 06:04 AM   #9
CLASS "A" Senior Member
cfsoistman's Avatar
X3
Whenever I hook up my car to the coach I always use the Tow / Haul feature.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 09-14-2012, 06:36 AM   #10
mkillora's Avatar
A trucker's rule of thumb is to use the same gear going down the hill as you used going up it.
mkillora is offline   Reply With Quote
