Old 03-20-2014, 09:53 PM   #21
Oklahoma Proud
MillerTime's Avatar
Heres a pic of offset bushings. I think these are for a vw or sandrail though. I cant find any for HD applications, but they are very common on 4wd solid ft axle vehicles, such as f250, f350 and so on.
MillerTime- Future Sabre Handler!!
Old 03-20-2014, 09:59 PM   #22
But FT Turbs was talking about offset kingpins, not just bushings. I used offset insert bushings to increase or decrease timing gears when we raced sb Chevy's.
Old 03-20-2014, 10:14 PM   #23
Oklahoma Proud
MillerTime's Avatar
Originally Posted by f1100turbo View Post
On Solid axles you can adjust camber or caster with offset king pin busings.
On rare occasions camber can also be set by heating and bending the axle
But not very common.
TURBS
Sabre owners united!
Looks like "king pin bushings" to me
Old 03-20-2014, 10:16 PM   #24
TURBS's Avatar
That's what I said brutha!
TURBS
Old 03-20-2014, 10:16 PM   #25
Oklahoma Proud
MillerTime's Avatar
Or actually "busings" if someone wanted to get technical
Old 03-20-2014, 10:20 PM   #26
The bushings for solid axle king pins are straight, not tapered and made of bronze/brass to allow the spindle to rotate. The king pin bore in the axle is straight with a set screw/bolt to lock the king pin in the axle to prevent it from turning. At least all I've seen are like that.
Old 03-20-2014, 10:22 PM   #27
TURBS
Show us the offset king pins! To change a phrase, "No Pics, don't exist"
Old 03-20-2014, 10:32 PM   #28
Oklahoma Proud
MillerTime's Avatar
You place one offset at the bottom and one at the top- then you can use a straight king pin. Seems kinda simple to me, just different degrees installed as a pair on each side. At least that is how I would assume it to be, thats the only way I know it would work.
Old 03-20-2014, 10:38 PM   #29
All I can say is get a pair of them and try it, bet you can't get it to work by putting them in a short pc of pipe for the tapered bushings and then put a straight pin thru both of them especially if they are rotated even a little bit in relationship to each other, but if they are not, all you've done is move the kingpin front to back, not changed the inclination with respect to the axle.
The only way I've ever seen on anything except a racecar is with wedges or bending the axle.
Old 03-20-2014, 10:51 PM   #30
Oklahoma Proud
MillerTime's Avatar
Ok.
I know I could do it with somekind of index mark or a hex head like those I posted. Im pretty good a lineing up difficult metal
