Old 05-12-2013, 07:03 PM   #11
BigGeorge's Avatar
Originally Posted by Lawfive View Post
If you have the Kwikee steps always brace them when you are camping. The linkage will eventually break and that's a fun time when the step gives way under you. Keep some duct tape around too cause the steps just flap around loose when the linkage breaks. Luckily it happened to me when I was pulling into my storage location. Long zip ties zipped together would probably be even better. You can't drive the rig with the steps flapping. Not a good design after I got to spend time with it. While the linkage looks strong, its just chromed iron and it fatigues from your weight on the step. I now avoid the very bottom step till I get it supported.
What do you use to support them? Thanks.
BigGeorge is offline   Reply With Quote
Old 05-12-2013, 07:13 PM   #12
VinceU's Avatar
Short stack of wood pieces different thickness, some use a small screw jack. For sure a good idea, keeps wear down on joints.
Old 05-17-2013, 09:33 PM   #13
mr.ken's Avatar
Wound up being voltage. Charged up the new batteries and it works fine
2010 Georgetown 357qs
2009 chevy hhr
2007 chevy silverado
mr.ken is offline   Reply With Quote
