Old 09-10-2015, 11:22 AM   #1
Step won't go all the way in or out, Noise
My steps won't go all the way up or down and make a noise while doing so... I looked at previous forums on this... lubed it up, still didn't work.
Any thoughts on what the problem is and/or how to fix it?
philthy99 is offline   Reply With Quote
Old 09-10-2015, 02:02 PM   #2
Iggy's Avatar
Steps are bad.
How old is your Georgetown?
Have you contacted your dealer or Forest River yet?
Old 09-10-2015, 02:24 PM   #3
1 Year old. Going to do that next.
Old 09-17-2015, 10:35 PM   #4
gmann55's Avatar
Gear is stripped in the motor. Just had same problem with the same steps. Replaced motor which has the gear with it! Works great now!
gmann55 is offline   Reply With Quote
Old 09-18-2015, 09:42 AM   #5
MarkAnne's Avatar
My steps go in and out ok but the motor sounds like it cycles four or five extra times when they go out. This started after I washed the steps with a hose in preparation for painting them. It seems like spraying under the steps with a hose should not be an issue since they are exposed to weather anyway. Replacement motor and controller are pretty pricey and I don't know which is the problem. Any thoughts?
2010 Georgetown 337 DS
MarkAnne is offline   Reply With Quote
Old 09-18-2015, 03:45 PM   #6
jergeod's Avatar
The motor is a window motor out of a Taurus Ford you can get it at a local auto parts store about $40
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 09-18-2015, 05:42 PM   #7
I have an extra motor if you need one. I have the 3 step lippert type.
PM me and I'll send it to you if they are a match and this is the problem.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 09-21-2015, 04:39 PM   #8
Cornelius's Avatar
MarkAnne, I had the same problem a couple of years ago with the step motor making 4 or 5 knocking sounds when it operated. A replacement motor solved the problem. Here's some information I posted about it back then. Hope it helps:
The motor used for the Lippert steps on the Georgetown is a Ford and Lincoln power window motor. They are available from Car Quest, Advance Auto Parts, O'Reilly, etc. for about $50. You will need to cut and reuse the electrical connector off the old Lippert step motor, as it is different from the Ford connector.
Two manufacturers available:
ACI part # 83694
Cardone part # 42-309
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 09-28-2015, 06:42 PM   #9
2012 Georgetown...My Step Broke the third outing. Replaced under warranty. Just got back from a 3800 mile vacation and step broke again (on the road). This time I did the modification myself in camp. Drilled out the ball pin and replaced it with a new SS Bolt. Works better than new! I just may call it "FIXED".
ALLAND is offline   Reply With Quote
Old 11-27-2015, 05:18 PM   #10
What model year on Ford Taurus for the window motor?
scooter313 is offline   Reply With Quote
« A/C Unit | RV show »
