Old 07-07-2015, 11:04 AM   #1
Steps
Well as I have read in some other posts in regards to the electric steps, our 350TS now has issues with the electric steps.
Once the steps extend there is a clicking noise for about 10 seconds.
Did this for about 1 week before I had the time to investigate.
As soon as I began to investigate the issue it began doing it on the retraction as well.
Could this be the electric steps motor and the amperage over sensor built it not shutting down the motor properly?
Could this be the triangular gear inside the motor slipping within the plastic bushing?
Any help would be greatly appreciated.
Thanks in Advance
chrislynch2014 is offline   Reply With Quote
Old 07-07-2015, 01:43 PM   #2
Weekender
Ford1's Avatar
I would guess that this is the reason, "Could this be the triangular gear inside the motor slipping within the plastic bushing?" If the steps begin to stop part of the way through the cycle and act as if they are being bumped, you can be sure that that is the problem.
Ford1 is offline   Reply With Quote
Old 07-07-2015, 10:29 PM   #3
Not stopping mid cycle
Steps operate correctly just clicks like something is slipping.
I have watched the operation from under the coach and all appears well.
Clicking noise on both the extend/retract cycles is coming from with the motor housing that has the worm screw driving the pinion gear that moves the steps.
Old 07-08-2015, 03:17 PM   #4
We had exactly the same problem. Be prepared to replace the step motor assembly. Sorry.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 07-08-2015, 06:43 PM   #5
Tim & Lisa Trempert
Thanks in Advance
More than likely the three bolts that hold the motor are loose. This lets it skip gears and the run to the end of the triangular gear and start clicking. You may even be missing one of the bolts. There are bushings as well, so if you need to remove the bolts, don't lose the bushings.
I fixed mine about 3 years ago and no problems since then other than the center bolt broke last year and I replaced it. You don't have to remove the steps, but it sure makes it a lot easier. Just 4 bolts hold the steps on. Unplug the wire harness, unscrew the ground wire and I had to cut one wire which I then reconnected using an unplugable connector on. I imagine in the next 5 years I'll have to replace the center bolt. If nothing else, another good paint job.
If you'd rather spend $400 for Kwikee steps some are doing that. I prefer the less expensive, but permanent, fix.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-12-2015, 11:37 AM   #6
n1joh's Avatar
Sounds like the center bolt is coming loose be care full whe.n you step on stares
n1joh is offline   Reply With Quote
Old 07-13-2015, 10:52 AM   #7
Smile Step problem
The motor that drives the steps is a automobile windshield wipper motor and can be purchased at an auto parts store. I replaced mine with no trouble and it has worked great for the last two years. I do not know the part number, but it is a direct replacement.
Thom Thom is offline   Reply With Quote
Old 07-13-2015, 12:05 PM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
Thanks for the info.
Greatly appreciate the shared wealth of knowledge here.
I know the headlights on my 2007 Georgetown are the same as the 2007 Ford F-150 Pick-up Headlights. I've seen them both listed on eBay and the difference is usually about 30 to 35 percent when the Georgetown RV name is in the listing.
and Be Safe !
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-15-2015, 06:56 PM   #9
What kind of steps on a 2013Georgetown 335DS are they kiwkee ?
Don
Donlock is online now   Reply With Quote
Old 07-15-2015, 07:21 PM   #10
LCI-3 Step
Replaced motor
All good now
