Old 11-24-2010, 08:30 PM   #1
steps
When storing 378ts how do you retract steps without jumping out
Railroadman is offline   Reply With Quote
Old 11-24-2010, 09:33 PM   #2
Canadian Georgetown 350ds
Schwing2008's Avatar
I have a 350 DSSE and how i do it it shut the screen, and the steps go in and then slide the opening of the screen handle to shut the main power switch off
Randy
Edmonton Alberta Canada
Schwing2008 is offline   Reply With Quote
Old 11-25-2010, 09:42 AM   #3
Hey Schwing --- are you my old friend, the blinged-out Gold Wing rider from Edmonchuk ??? (your rig looks familiar !)
...VTX-AL
VTX Al is offline   Reply With Quote
Old 11-25-2010, 03:54 PM   #4
VTX, yes I am from St. Albert
How do I know you
Randy
Old 11-25-2010, 07:43 PM   #5
Steps retract
I use a magnet, place it over the door sensor switch on the inside of the door frame, this retracts the steps (thinking that the screen door is now closed), I then turn the power switch off and then close the door to the RV which pushes the magnet off the door sensor. Voila!
Guy Lacroix is offline   Reply With Quote
Old 11-28-2010, 01:14 PM   #6
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
The magnet is a great idea. We have a set of steps we used with our fifthwheel when we were in texas for the winter and I couldn't figure out how to disable the steps on the motorhome so I could use the other steps. So, I took the battery cover off and closed the screen door to retract the steps and had my wife lay on the floor above the steps and unplug the wires going to the step motor. With a magnet I can do it myself and the plug is much easier to reach standing on the ground outside the door. Thanks for the great idea.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
