Old 03-22-2016, 02:11 PM   #21
Happily Retired Member
I had the same problem on my 378, the 5 amp fuse was blown. Replaced the fuse and all is well.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 03-23-2016, 01:04 AM   #22
Where is the fuse????
Preadus is offline   Reply With Quote
Old 03-23-2016, 01:13 AM   #23
ramair's Avatar
The fuse is under the steps where the batteries are.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-23-2016, 06:04 AM   #24
bubbles's Avatar
Don't you read these posts? Look at post #20. Also, if you would tell us what model Georgetown you have it might help so someone with the identical model can tell you where the battery control center is located (fuse is inside it). Its location may be different for each model. The fuse may be your issue if you have Kwikee steps.
