Old 03-18-2016, 08:51 PM   #1
Steps won't stay down.
Has anyone else had this problem. I can't get the steps to stay down. Parked, motor off, plugged in, in plugged, etc.
any advise?
Preadus is offline   Reply With Quote
Old 03-18-2016, 10:08 PM   #2
ramair's Avatar
There is a switch that you have to turn on, with our 378XL its right by the door and by the master cutoff switch. There are 3 rocker switches in a row, 1 for the steps, 1 for the outside lights, and 1 for the inside floor lights. Hope this helps.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 03-18-2016, 10:47 PM   #3
Sadly it will not stay out even after flipping the switch either way.
Old 03-19-2016, 09:20 PM   #4
Dijoeboss's Avatar
Before Lippert replaced my steps, the orginal steps would do whatever they wanted, I would have to crawl under the steps and unplug the motor to get them to stay out, so far, my new steps have worked like they are supposed to!!
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 03-19-2016, 09:27 PM   #5
World Wide Wanderer
wahoonc's Avatar
Chance it may be wired wrong, or even not wired.
This how mine works:
  1. Open Door
  2. Ignition must be OFF
  3. Flip stair switch
  4. Close door and see if step stays out
FWIW the screen door by itself should operate the stairs.
If this doesn't work, get it checked out under warranty.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-19-2016, 09:41 PM   #6
I have tried all of the proper steps and it still will not stay out. It worked before. I wish I knew what to check.
I doubt it's under warranty because it's a 2014.
Old 03-20-2016, 05:52 AM   #7
fonzie's Avatar
Here is instruction/troubleshooting manual for Lippert steps....if after all test completed and still not operating properly, you might have to change the control module...
Manual and Power RV Steps for Sale
https://www.etrailer.com/Accessories.../LC301702.html
Name:	Lippert Step Switch 72 Schematic.jpg
Fonzie
Old 03-20-2016, 06:52 AM   #8
World Wide Wanderer
wahoonc's Avatar
Based on that schematic I would check the switch connections first. Could be a bad switch. That fact that it has worked in the past means something has either disconnected or failed.
Aaron
Aaron & Rhonda
Old 03-20-2016, 10:05 AM   #9
bubbles's Avatar
If you have Lippert steps this doesn't apply. If Kwikee steps the step switch needs to be on for steps to stay out. The battery control center provides a 12 volt input through the switch that is required. The 5 amp fuse in the center may be blown. The switch light will illuminate if the fuse is ok but the light has its own ground and the wire from the switch to the steps connector could be open. Worth a check. If Lippert steps the switch is off for the steps to stay out and therefore no 12 volts is not an issue.
Old 03-20-2016, 10:48 AM   #10
I put a switch in the wireing to the door mag switch to keep steps in or out as we go on ferries and borders and can not have them coming in and out, had this on my other
Motorhome to. It works for us.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
