Old 06-23-2012, 08:25 PM   #1
Freds342's Avatar
Storage Bay Lighting Power Source?
Has anyone ever figured out where the power to the storage bay lighting comes from in Georgetowns?
I know there are probably different sources for different units, but maybe......
I had a piece of shade material shift in one of my bays and turn the light on, almost starting a fire. I have since removed all of the lights from any bay that I think this may happen in, and don't miss them, but thought I'd warn everyone else, and look for a common solution.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 06-23-2012, 09:48 PM   #2
Don't have a mh, but put microswitches on all the storage doors, which automatically shuts the power off when the door is closed. That might be a possible solution to your problem.
Old 06-26-2012, 12:25 PM   #3
Freds342's Avatar
Thanks for the input.
Maybe mercury(type) switches, but even that would be a PITA with so many doors.
A common-source switch would be better, and I'm gonna investigate as soon as it gets a little cooler out!
Old 06-26-2012, 08:30 PM   #4
Tim & Lisa Trempert
My 2011 350 didn't come with storage by lights. Did anyone else get lights in their storage bins? I'm wondering if they were left out in error.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-26-2012, 08:58 PM   #5
georgetown's Avatar
I don't think the newer motor homes come with lights in the storage bays, not sure what year they stopped in. We have a 2010, no lights, but I did put my own in. I used LED strips and they are controlled by a switch just inside the entry door that I added by the other factory switches.
2010 Georgetown 330
Ontario, Canada
georgetown is offline   Reply With Quote
Old 06-27-2012, 02:29 AM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
I have lights in every compartment as well as one under the hood and one in the trunk. On my unit there are two switches as you walk in the coach just to the lfet of the steps near the bottom of the cabinet. They are along with the step switch, floor level aisle lights switch, they are labeled as Roadside Lights and Curbside Lights.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-27-2012, 06:40 AM   #7
armye7's Avatar
My 2012 378 has lights in the storage bins, the 2011 did not have them.
armye7 is offline   Reply With Quote
Old 06-27-2012, 08:25 AM   #8
Send a message via Skype™ to Falcon35
My early 2012 has no lights in the storage bins. When I had a tour of the factory in April they were building the new model of the 2012 and they had the lights. It seems that if you have the new front cap and the higher roof (and higher price) you will have the storage lights.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 06-27-2012, 01:18 PM   #9
Freds342's Avatar
Interesting "evolution"! My 2000 Georgetown 342 even had lights.
I have never (intentionally ) used them, so I'll probably just remove the bulbs.
Old 06-27-2012, 01:47 PM   #10
B47
Trempert - Ny 2012 Silverback 29rk came with lights on both sides of the pass though compartment. They are mounted over the doors and are manually operated.
For a little more information on these lights as well as the two LED ones mounted in the front cap, search "2012 Silverback 35QB4 External Cables/Satellite Outlets" and start with Post #6.
Edit - In re-reading your post, I see that are talking about a MH - my 29rk is a FW. Sorry for the confusion.
B47 is online now   Reply With Quote
