Old 06-10-2014, 09:57 AM   #1
Stove & Furnace main slide side
I have a Georgetown 378. The furnace and stove on the driver side will not light. Furnace blower comes on but stops when burner does not light. This is on the main slide side. Appliances (Furnace, Refrig, Water Heater) on the opposite side seem to be working OK. Stove will light sometimes but with a very low flame. Any ideas?
hlewis is offline   Reply With Quote
Old 06-10-2014, 10:00 AM   #2
Ford Idaho's Avatar
Look underneath the slide for a kinked gas line.
Old 06-10-2014, 12:04 PM   #3
Update with slide in everything works fine. Other than underneath the coach how would you look for a kinked line? Can see no problem from underneath
Old 06-10-2014, 12:26 PM   #4
Ford Idaho's Avatar
Under my slide there is a vertical plastic strap that the power lines are tied to, each end is hooked to a steel rod that holds the strap and allows it to move with the slide.
I suspect your problem is near where the gas line comes from the main body to the slide.
furnace, slide
