Old 03-09-2014, 06:01 PM   #1
ateepay's Avatar
Suburban water heater electric ????
I found this statement from a 2008 question here. We have a 2004 Georgetown and hubby just said, "where the heck is that?"
Here is the statement I found: "There's a 120 volt breaker in your fuse box that goes to the WH. If you want to run the electric element then obviously that must be on."
Where is the breaker? Is the circuit breaker for just the water tank or for all the 110/120 throughout the coach.????
2004 Georgetown 32'
ateepay is offline   Reply With Quote
Old 03-09-2014, 06:08 PM   #2
fonzie's Avatar
Usually breaker will be in breaker panel as shown below if you have a gas/electric water heater...it is a dedicated breaker for the water heater
Fonzie
Old 03-09-2014, 06:23 PM   #3
fonzie's Avatar
Here another photo....
Name:	breaker panel cover.jpg
Fonzie
Old 03-09-2014, 06:29 PM   #4
Ford Idaho's Avatar
All of the black colored breakers should be 110/120 volts.
All of the small colored fuses should be 12 volts.
electric, heater, suburban, water, water heater
