Old 04-13-2011, 01:41 PM   #11
Jammer6921's Avatar
Was that process of reprogramming very difficult to do ??
Rodney & Karen
2011 Forest River Cherokee 28BH
2004 Chevy Tahoe
Jammer6921 is offline   Reply With Quote
Old 04-13-2011, 01:43 PM   #12
Took exactly less than 3 minutes to do
remember is offline   Reply With Quote
Old 04-13-2011, 01:44 PM   #13
kvtaylor's Avatar
I doubt if you can save enough to justify a chip in the ford V-10 engine. We have the edge chip in our 2005 GMC 2500HD and yes, it did make a little difference in the performance, but little in the fuel savings. I doubt if I would ever do it again. We used to tow 14000 lbs of 5th wheel and I thought I would get more performance than I did with the chip. It was expensive and I know it didn't pay for its self in the two years we towed the Montana. Our 2008 Georgetown has plenty of power even with towing 3500 lbs of car.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 04-13-2011, 01:47 PM   #14
Thanks for your reply
I also have plenty of power in my Georgetown ,I was just wondering how to get some economy
Old 04-14-2011, 11:39 AM   #15
Oh boy I am gonna watch this post...does chipping nullify the warranty in any way????
polkatronron is offline   Reply With Quote
Old 04-14-2011, 11:49 AM   #16
My neighbour chipped his 2006 chevy diesel, stretched the head bolts and blew a head gasket. Many thousands of dollars later, he is looking pretty sheepish.
Oh, and he is also on his third set of injectors, and those puppies ain't cheap. Or is it the fourth set?
Old 04-14-2011, 12:13 PM   #17
You must be careful with the brand of chip you buy
It seems that the EDGE brand is good
And also some people who put those chips thinks that their engine is totally without any failure. As I said I had one on my gmc 6l and neveu had a problem. And to answer thé éther question with thé Gand gels programmer when you go to the dealer,you just have to put the programmation back to normal before going.
Old 04-14-2011, 12:16 PM   #18
Sorry for mistyping some words
I was meaning that when you go back to the dealer,you just need to use the hand held programmer and put it back to normal
Old 04-14-2011, 05:50 PM   #19
sherdep's Avatar
I have a superchips programmer with the shift point tuning - it takes longer then 3 minutes to tune the truck - I am using it on a Dodge - I can change the shift points in my transmission as well as set the tune from "stock" to "Towing" to "87" to "91"
with the towing tune and 91 tune I have to run High test gas (91 octane)
You can program the truck back to "stock" before taking to the dealer - If a dealer finds out you programmed the truck it can void your warranty.
I also use my programmer to set my tire size correctly so it sets the correct pinion factor for the spedometer and ABS since I am runing larger then stock sized tires.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
