Originally Posted by Tbonz
My SURGE GUARD model 35550 has tripped 3 times in the past 24 hours. Twice in the past hour. I have checked power at the pedestal and have 124 volts on both legs. I have had this SURGE GUARD for 6 months and this is the first problem we have had..Will call surge guard in the morning.
This may not be so much a problem as it is a blessing. If it's working correctly, it is likely finding something wrong either on the power (line) or trailer (load) side of the protector.
Other than voltage and amperage readings, is the LCD display showing any codes or problems once it has tripped?
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
