View Poll Results: Portable or Hardwired?
Portable - EMS-PT50C 22 47.83%
Hardwired - EMS-HW50C 24 52.17%
Voters: 46. You may not vote on this poll
Old 09-03-2014, 05:28 PM   #11
TURBS's Avatar
Hardwired.
Helped install "2" hardwired units at the rally.
Total install time each?
About an hour.
TURBS
"SABRE OWNERS UNITED"
Old 09-03-2014, 05:43 PM   #12
AquaMan's Avatar
Originally Posted by f1100turbo View Post
Hardwired.
About an hour.
TURBS
I can testify to that.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-03-2014, 05:47 PM   #13
davel1971's Avatar
hardwired with remote (which I have), you can bypass if necessary just with the flick of a switch on the remote panel you mount in the RV
David & Lynn
Old 09-03-2014, 06:13 PM   #14
Brewjaz, when you plug in the hard wired version it checks all parameters before it allows any current to pass through to the load. If there is a problem it will not allow power to the load. There is also a delay of about 2 1/2 minutes before the relay closes after a power interruption to prevent rapid recycling of the AC compressor.
I installed the 50A version and the only difficulty was the stiffness of the wires. Certainly not a deal breaker but still a little troublesome for me anyways.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 09-03-2014, 06:40 PM   #15
Kaadk's Avatar
As I covered in another thread, I went portable because I know I'm eventually going to switch from a 30A trailer to something that's 50A, and I figured I'll get better resale out of a portable unit.
But, if this was an 'end of the line' unit, where I don't see myself swapping rigs shortly, than I'd have preferred a hardwired.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 09-03-2014, 07:37 PM   #16
I vote and installed a hard wired type
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 09-03-2014, 08:18 PM   #17
Mr. Dan's Avatar
I vote and ordered the hardwired.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 09-03-2014, 09:17 PM   #18
GABoy's Avatar
I vote hard wired. I installed mine and it caught faulty wiring on pedestal of first trip out!
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 09-04-2014, 07:10 AM   #19
360true's Avatar
I have a portable. I am able to check the outlet before plugging in. Recently was at a remote campsite where I found three of four power pods had a problem. Is the first thing I doing in my setup process so our is ready to move rig of I must. I do like the idea of cutting the main power cord and with plugs install the portable so it stays inside the power cabinet. Also then can insert a short end of the power cable from the bottom instead of snaking 35' through the porthole. On my list to do!
360true is offline   Reply With Quote
Old 09-04-2014, 07:30 AM   #20
i got the portable for 2 reasons: 1. i was in a hurry and wanted to get going on my camp season and 2: i wanted to plug it in at each site and see the readouts prior to plugging in my power.
the device is not heavy and is easy to use. i like it.
fullenw is offline   Reply With Quote
