Old 06-24-2015, 01:54 PM   #1
Suround sound on tv...are there certain settings...We've tried almost all combos. Is t
Georgetown 378xl 2015
anna33 is offline   Reply With Quote
Old 06-24-2015, 02:07 PM   #2
karrun's Avatar
IF you aren't hearing the TV sound through your speakers, the TV probably isn't hooked up to the correct input on the stereo. Mine was hooked up to TV out. Needs to be hooked up to TV in.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 06-24-2015, 02:44 PM   #3
rsscully's Avatar
Don't have a Georgetown, but for me it was just a matter of going into the balance/fader setting and moving the fader more toward the rear. Anything center and forward of center only played through my door speakers.
rsscully is offline   Reply With Quote
Old 06-24-2015, 04:03 PM   #4
It may only work if hooked up to the radio unit with an HDMI cable
Good Luck...many many post here on that topic...
David 01 is offline   Reply With Quote
Old 06-26-2015, 05:27 PM   #5
After alot of reading and scratchen our heads .....tada we figured it out after ohming some wires that went to the front gps panel (clarion) from the tv...we simply did not have the right set up...well it wasnt all our fault it was,after all, as clear as mud. It is working now, thank you all
