11-12-2019, 04:03 PM
Suspension
Anybody do any suspension upgrades on a Forestriver Georgetown XL Sumo springs, sway bars, stairing assist ?
11-12-2019, 08:35 PM
Lots of people have done all, part or none of it! What exactly ar you trying to accomplish?
I bought mine with everything done by the previous owner. I belive they had stability issues, which stemmed from the excessive toe out I found after I drove it home.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
11-13-2019, 01:13 AM
Installed Sumo springs, front & back.made a big difference.
Next month installing Koni shocks.
11-13-2019, 10:06 AM
Too much play in steering wheel and to much roll when entering some gas stations .
11-13-2019, 10:07 AM
What year and model is your coach ?
11-13-2019, 01:28 PM
Looks like you have a 2019 Georgetown XL by your profile. Have you looked at the CHF (Cheap Handling Fix) that should take care of your roll going into a gas station. As for the steering, well these have some play on them. You may want to start with an alignment. If it’s out it will feel like it has a lot of play due to fighting the wheel back and forth.
11-13-2019, 03:50 PM
Thanks appreciate the advice , will check it out
11-19-2019, 12:34 PM
Fireman
We have a 2013 Georgetown 378Xl I have done all that, the last thing I did was install sumo springs and it rides 100% better, I installed a 1 3/4 sway bar in the front from a 1 1/2,
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
12-07-2019, 01:11 PM
Went for the Full Monty
When the Mothership was in the shop I had Roadmaster front and rear heavy duty sway bars put in, Safe T Plus steering stabilizer and summo springs front and rear installed. After recovering from Emergency Room treatment for total costs I can now drive with one hand.
The quick fix with just a pair of front summo springs could do the trick. Take baby steps as each rig is different.
2019 Georgetown 31B3 - The Mothership
Roadmaster front and rear swaybars
Safe-T-Plus steering stabilizer
Summo springs front and rear
12-07-2019, 03:44 PM
I started with a front alignment, then did the CHF, and finished with the sumo springs. It is handling great now, just still doesn't like side winds. Oh well, you can't have it all.
2014 Georgetown XL 378ts
