Old 02-23-2015, 07:18 PM   #11
Tim & Lisa Trempert
Do you have any pictures you can post?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 02-23-2015, 07:49 PM   #12
tilap's Avatar
Trempert Click image for larger version
Name:	ImageUploadedByForest River Forums1424742372.276458.jpg
ID:	70115Click image for larger version
Name:	ImageUploadedByForest River Forums1424742403.897890.jpg
The first one as you can see the fender sit below the top of the tire, the second one is with the jacks down and it show where the tire and the fender should actually sit in relation to each other. You can see also where the crack form along the fender when the tire hit the lip of the fender.
Denis, Forest river Georgetown XL 377 towing a 2014 Ford Explorer.
tilap is offline   Reply With Quote
Old 02-23-2015, 09:21 PM   #13
ramair's Avatar
Iggy may be on to something and I also think it has to do with your shock compressed which is causing your sag. If you can get under the rig and take some pictures of your springs and shock on the sag side and then take pictures of the good side. That my help us trouble shoot.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 02-24-2015, 11:27 AM   #14
Coach 350's Avatar
Kind of agree with Iggy on this. It sounds like a bad shock absorber. Curious to see what the diagnosis is.
Coach 350 is offline   Reply With Quote
Old 02-24-2015, 11:36 AM   #15
miked11272's Avatar
Suspension?
Georgetown side wall bolts sheared off- and a fix!
The shocks don't effect the height. The leaf springs control the height. Check out the thread above this is a common problem with FR products the sidewall bolts break mine broke at 11,000 miles.
miked11272 is offline   Reply With Quote
Old 02-24-2015, 11:44 AM   #16
Iggy's Avatar
Originally Posted by miked11272 View Post
Georgetown side wall bolts sheared off- and a fix! - Forest River Forums
Shocks could effect height as If they are dual action gas shock. Both up and down and do take some weight off the leaf springs.
Hopefully he will find out what went wrong soon.
Old 02-24-2015, 11:48 AM   #17
dieselguy's Avatar
Does your unit have a kneeling feature when you setup at a site? (Coach drops down closer to ground for easier access) If so, perhaps it didn't automatically return to drive height when you started it up to leave the site.
dieselguy is offline   Reply With Quote
Old 02-24-2015, 12:11 PM   #18
tilap's Avatar
Mike11272 Thanks i looked and I didn't see anything out of place. After going back and forth between Ford and FR. I will take it to Ford in davenport FL next week if they find nothing wrong with their chassis then 200$ out of my pocket and then I Will have to go back to FR.
Old 02-24-2015, 12:12 PM   #19
tilap's Avatar
Dieselguy no
Old 02-24-2015, 12:29 PM   #20
tilap's Avatar
Ramair I am all set up with the jacks down therefore not much weight on the springs or chocks. I don't think it would tell us anything right?
suspension
