Old 03-06-2015, 04:11 PM   #31
tilap's Avatar
I guess a crack developed. As for having Ford weight it, I think it is going to be hard to do. Not sure I want to off load everything leaving at the camp ground and then reloading everything. If I was home good idea but on a trip?
Denis, Forest river Georgetown XL 377 towing a 2014 Ford Explorer.
tilap is offline   Reply With Quote
Old 03-06-2015, 04:27 PM   #32
Well at least you know what it is now, but now the battle begins as to who pays for body damage. Good Luck
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-06-2015, 05:15 PM   #33
abjb's Avatar
Forums are pretty anonymous so I can ask the BIG question .
Why would you "off load everything leaving at the camp ground and then reloading everything" unless your overloaded?
Like I said "anonymous" so if you are overloaded Ford shouldn't be able to trace this back to you.
Like the goodol tuned 6.0 blown head gaskets, Ford fixed thousands under warranty, "Just reinstall the factory software and take it in,,,FREE."
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 03-06-2015, 05:30 PM   #34
tilap,
Why not get the unit weighted before you unload and after. Even if you just get the front and rear axle weights. If you weight it and it is under the axle and spring ratings you have some proof to show Ford that it is good. If you weight it and you are over you know what could have caused the problem. The units are weighted when build and you should have the yellow tag telling you what room you have left for our stuff.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 03-06-2015, 06:16 PM   #35
Originally Posted by youroo View Post
You must have (ERS) don't drive it,call (ERS) and let them (Transport) your unit to Repair Facility! Youroo!!
I find this whole situation very ODD that a person has a Fender (Several Inches Down and Rubbing a Front Tire) would (Drive It )! Then drive it to a FORD DEALER and they (Confirm that Your Front Spring is BROKEN) and they let you (DRIVE AWAY)! Youroo!! Two things come to mind here, (SAFTEY and STUPIDY)!
youroo is online now   Reply With Quote
Old 03-06-2015, 08:18 PM   #36
tilap's Avatar
does it say anywhere that the vehicle was driven anywhere?
Old 03-06-2015, 08:42 PM   #37
tilap's Avatar
Rgmiller32 the vehicle was weighted before I loaded it for the trip and after loading and everything was below max recommended limit. I still got the official scale receipts with all the details of the weight. I should have add some details like to get the vehicle to Ford I got it towed and had to empty it as as possible. Then got it Towed back to the campground. It will get towed back to Ford.
Old 03-06-2015, 08:45 PM   #38
B and B's Avatar
Sounds like a good way to prevent damage any further. I certainly understand what you are doing and up against getting parts. Best of luck getting service completed and not totally ruining your time away on vacation.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-06-2015, 09:01 PM   #39
It would have been (Easy/Nicer) to Tell us that you had it towed (Back and Forth) to the Ford Dealer instead of your Post # (18/26/29/and31) My Post # 8 said Tow It! Youroo!! Remember YOU ask for Help!
Old 03-13-2015, 09:43 PM   #40
Dijoeboss's Avatar
Suspension?
If the unit is NOT overloaded and Ford is fixing broken spring under warranty, they should repair the fender damage as progressive damage. IF they won't fix the fender, I would think that they shouldn't replace the spring asy under warranty. ( Not all Ford dealers have a body shop, may need to get repaired at a body shop you choose and present the repair receipts to your local Ford dealer for warranty reimbursement. Might even contact Ford Customer Service. )
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
suspension
