Originally Posted by donanddona
Not familiar with this sway bar/pin location, however is it possible to use both inner and outer locations with an additional set of pins?
You just move the "pins" from the outer sway bar holes to the inner on the front.
The back requires moving 2 brackets, 4 bolts on the back.
The reason it's called "Cheap Handling Fix" is it's free, only requires basic hand tools and make a BIG difference in the way your MH handles!
And is probably the easiest DIY you'll ever do.
Take a look at this thread.
http://www.forestriverforums.com/for...fix-62663.html
ab&jb
