Old 06-29-2014, 06:53 AM   #1
Tainted water tank
Our '14 351DS had a tank full of water that didn't get emptied after last trip. When hubby opened filter it was gross. We emptied tank, but now I'm worried about what is growing in there. I remember reading about chlorox in the tank. Can anyone tell me the ratio, as well as how we get the Clorox in the tank? Should we replace the filters in the fridge ice maker and water also? Thanks so much.
Campingmomx4 is offline   Reply With Quote
Old 06-29-2014, 07:21 AM   #2
kc8lvy's Avatar
From what I read on here and I do this a couple of times a year is 1/3 cup of bleach to 15 gallons of water. I have a 66 gallon fresh water tank so I use about a cup for mine. I just pour it in my hose that I fill my water tank with then hook it up and fill the tank. I open the faucets until I can smell the bleach then shut them off. I let it set a few hours then drain tank and refill with water run faucets again then drain tank again.
2004 Dodge Ram 2500HD Cummins
2013 Cedar Creek Silverback 33rl
kc8lvy is offline   Reply With Quote
Old 06-29-2014, 07:22 AM   #3
AquaMan's Avatar
I use about a cup per 15 gallons or so. This may over do it some, as some say as little as 1/4 cup per 15 gallons. Mix bleach with a gallon if water and add to tank using a funnel. Add more water to tank as you normally would. Turn on pump and open faucets until you smell bleach and let sit for a couple hours. If you can drive around a bit the water in tank will slosh around and coat walls and top. Drain you tank, fill with fresh water and run faucets. Rinse tank a couple times, then hook up city water line and run through the faucets until clean
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 64
Old 06-29-2014, 07:22 AM   #4
Do a Search at the Top! Many Info Posts on (Mixture & Method). If water is that Nasty replace all Filters! Youroo!!
Old 06-29-2014, 08:02 AM   #5
Ford Idaho's Avatar
I use 1/4 cup per 15 gallons of water.
It is suggested you let it sit over night to 24 hours.
After that refill the tank and drain till you can no longer smell the bleach.
Be sure to run a few gallons of water/bleach thru every water faucet include the outside shower if you have one and the low point drains.
If you use RV antifreeze to winterize this is a good way to flush it out.
Ford Idaho is online now   Reply With Quote
Old 06-29-2014, 12:20 PM   #6
I have read that you should do both the cold and hot water (water heater included) systems. What will the bleach do to the anode rod, or should you remove it before sanitizing the system?
cgotto1204 is offline   Reply With Quote
Old 06-29-2014, 12:39 PM   #7
If your (Complete Water System) is Nasty,Treat the Complete System! All of it,Hot & Cold,Stored Water and City Water! Leave the Plug in the W/H. Youroo!!
Old 06-29-2014, 01:47 PM   #8
cjd10's Avatar
We have stayed at a few CG's that have what we call sulfer water. Nothing wrong with it, it just tastes different and smells bad. Longer it sits the worse it smells. We just have to flush the system with fresh water when we get home.
Just wondering if possibly you got something like that in your tank.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
tank, water, water tank
