Old 08-22-2016, 08:49 AM   #31
Man vs Squeek
Mouhahhahahahahahah.....I win, at least a little.
I finally killed the moist annoying side window squeek, creak, crack using pure silicone spray. I sprayed the track and seal all around the side window, then slid the window back and forth to spread it.
I love pure silicone spray, it dries completely, doesn't attract dirt, and conditions the rubber.
I can't believe how well it worked.
Modmike is offline   Reply With Quote
Old 08-24-2016, 04:26 PM   #32
AquaMan's Avatar
Thanks Mike! That's next on my list. Rig is going back to factory next week for slide work. They found a bent slide frame while replacing a seal, at Goshen. They're going to do the bed slide fix while they're at and anything else they find.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-24-2016, 06:57 PM   #33
Yikes! How do they figure it happened? Was it the bed slide?
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Old 08-24-2016, 08:00 PM   #34
AquaMan's Avatar
It was the front slide. They said it looks like the slide shifted in the opening and the top cable bracket caught the frame and bent it. Luckily it didn't gouge into the sidewall like they usually do.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-25-2016, 04:39 AM   #35
cjd10's Avatar
Will have to try this. Years ago on our 1st GT I sprayed lube around the edge of the picture tube on the TV above the driver to stop the creaking noise. Only had to do it once.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
