Old 09-06-2012, 09:55 PM   #1
Newellri's Avatar
The tv switch has only one line for both tv's
It must have a connector for both tv's does any one know where this connector is located? Thanks
Newellri is offline   Reply With Quote
Old 09-06-2012, 11:51 PM   #2
Iggy's Avatar
You need to tell us what year and model Georgetown you have.
On my 378 it is located underneath the passengers seat above the right front tire.
Old 09-07-2012, 05:18 AM   #3
Newellri's Avatar
It is a 2012 350. With the the storage instead of the bunks.
Old 09-07-2012, 05:21 AM   #4
Newellri's Avatar
Thanks I will go out and look when the sun comes up. Still dark in Omaha !
Old 09-07-2012, 11:07 PM   #5
Newellri's Avatar
Nope not there, must be behind the VCR wall,
Old 09-07-2012, 11:10 PM   #6
Iggy's Avatar
Did you see or find any coax under the rig ont he passengers side?
They do not put splitters hidden in the walls.
If you look again under the rig look for possible it wrapped in plastic covering or even tape.
Old 09-07-2012, 11:17 PM   #7
Newellri's Avatar
Will try again.
Old 09-08-2012, 09:25 AM   #8
VinceU's Avatar
TV Spliter 3 way
Will try again.
I located the splitter 6 months ago looking for bad outside TV connection. It was a bear because it's locacted behind the Switch/DVD equipment compartment. I removed all the switch plates, TV/antenna booster and A/C outlet to gain access to that huge space behind. The sat feed cables, all three TV feeds, DC wiring and AC wiring are back there. Using mirrors and by "fishing" the coax cables I finally located the splitter and checked it out. There is an electrical schematic in the forums for this app. From this splitter you can take individual control of the three outputs. I think Iggy was refering to Coax leading to the right slide in a 378. That run comes down the windshield pillar, aft in the fwd end and out a telecoping tube to the fwd end of the slide for the large TV. I'm also in a 2012 378.
That large space covers the entire width of the coach, behind and below the cabinets
Old 09-08-2012, 10:25 AM   #9
Iggy's Avatar
WOW!
Old 09-08-2012, 11:47 AM   #10
Newellri's Avatar
Found the coax, but their is only one coax under their. I will look next behind the mid tv. There is. Access behind the tv in the bath.
