01-13-2012, 11:00 AM
Those BIG openings for electric & cable?
Is there something that can be used to close those huge holes that will keep creepy crawlies out once the electric cord, cables & extention cords are run?
We had a couple of mice checking for new digs after just a couple of days of having the electric plugged in here at home and we've transported ....eeeek.....SPIDERS..... eeewwww..... and probably other arachnids & insects that have discovered the gateway into the storage compartments.
Karen
Enjoying the great outdoors with one hubby and 2 boxers! 2011 Georgetown 280DS
2010 Jeep Wangler 4x4 Toad
01-13-2012, 11:26 AM
There is a product called critter catchers or something like it that can be purchased and installed on those areas where the little rascals gain access. Being frugal, I purchased a foam kneeling pad from the Dollar store. I cut a circle the size of the opening and then cut it halfway through and cut a circle the size of my water hose in the center. I inserted it into the water hose access hole and ran the water hose through the center hole. I did the same for the power cord and have not had any critters. The sewer hose was a different story as it runs through a sleeve under the access area. I placed fine steel wool pads around the sewer hose at the point where it went through the floor. So far, no new friends. Total cost, $1.00 for the kneeling pad and $1.25 for the steel wool.
01-13-2012, 11:41 AM
aahhhh..... good suggestion!
Thanks!
Karen
01-13-2012, 01:31 PM
steel wool or even better is copper wool, (a copper scrubby)
01-13-2012, 01:39 PM
At a canine agility competition in Sacramento a couple months ago I got a couple of small frogs in the electrical compartment. Quickest little rascals l've ever chased around. Foam is my future. Thanks for the idea.
2007 391TS UFO Chassis
01-13-2012, 09:30 PM
Lottery Non-Winner
Had been just using some old towels and stuffed them in there. I may try the copper scrubbers.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
01-14-2012, 09:36 AM
Some of that spray in foam insulation would probably work too, for around the sewer pipe.
 Don & Carol Niemeyer and Sandy
2011 Georgetown 378TS
2011 Chevy Equinox Toad
01-14-2012, 01:07 PM
I just cut some pieces of plywood just a bit larger than the hole and then cut a notch out of one side to just fit the cable/hose. I usually put a rock on top of it.
Should stop larger critters. I may put some foam around the opening to make the opening even smaller.
I use it for the power, water, and the cables from my portable sat dish.
You can see it in the bottom corner of the picture
Stuart
01-14-2012, 03:08 PM
If you are talking about openings that get opend and closed during travel and depending upon use, try packing some steelwool in any gaps.
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 440 |
| 76 members and 364 guests |
| 2lvrvn, 4bnabird, armye7, Barney1, bayouboys, bean, biggie, bjcohn, bjlowe, BlakeB, BradinOhio, Cafjackracing, capucine, cardinal4fun, chof16, clormsby, DAISY BOYKIN, danred, Dodge Guy, electrician549, f1100turbo, Falcon35, Filthy Beast, fonzie, gljurczyk, GMS, Greene, grhodes50, Hamblen, Harley08, HemiCab, herk7769, hoffkm, hotrodj125, jamiller45, jaxfl, jaygeo1, Jim Hair, jmnorr3, Joseph5410, kybaja, KyDan, Mad4sax, MegaCabby, mike54, miked11272, MilCop4523, mtusrsmith, nailit, PapaSmurf, Pinesman, Pkdennis0504, plein air artist, railstar, realebill, redfox217, Redheaded blue tick, Rickstermn, Rsgtivr6, Russ, RV Guy, sail2liv, sandpiper, sellis1053, shrimper, SinkorSwim, skidoonut, softwarejoe, southernsky, tcoop48, tentcamper1, thomeyer, tls5150, transamz9, T_LMurphy, Wildhog56 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
